Dear billa:
My board can ping it,But I meet another qusetion,I want to use the udp protocol to send and receive message!Unfortunately I can't send.I want to use the board acts as client and send the message to computer.maybe my code lose someting important,could you help me check it?
waiting for your reply,thank you very much!
here is my code:
* Simple lwIP 1.3.1 example program.
* Expects no Operating System (NO_SYS=1)
* lwIP initialization and optional DHCP and WEB server support can be
* enabled by setting# defines described below.
* You must plug in your board's MAC address below before compiling!
* Contributed by: Bill Auerbach
lwip@softools.com */
# include <stdio.h>
# include <unistd.h>
# include "system.h"
# include "sys/alt_timestamp.h"
# include "sys/alt_alarm.h"
# include "lwip/init.h"
# include "lwip/netif.h"
# include "lwip/dhcp.h"
# include "lwip/tcp.h"
# include "lwip/udp.h"
# include "lwip/stats.h"
# include "lwip/ip_frag.h"
# include "lwip/ip_addr.h"
# include "netif/etharp.h"
# include "string.h"
# include "INC/alteraTseEthernetif.h"
# include "alt_types.h"
# include "sys/alt_irq.h"
# define mSdelay(x) usleep(x*1000)
//#define USE_DHCP 1
//#define LWIP_UDP 1
# define STATIC_IP IP4_ADDR(&lwipStaticIp,219,245,66,185)
# define STATIC_NM IP4_ADDR(&lwipnetmask,255,255,255,0)
# define STATIC_GW IP4_ADDR(&lwipgw,219,245,66,254)
# define STATIC_DA IP4_ADDR(&destAddr,219,245,66,112)
struct ip_addr lwipStaticIp;
struct ip_addr lwipnetmask;
struct ip_addr lwipgw;
struct ip_addr destAddr;
// Define BUILD_HTTPD to 1 to build the httpserver_raw contrib example
# define BUILD_HTTPD 1
// Alarm & timer variables - provides a 250mS counter
void lwipProcessTimers(void);
void Init_UDP();
static alt_alarm lwipAlarm;
static alt_u32 lwipProcessTimerFlag;
static alt_u32 lwipTicksPer250mS;
static alt_u32 lwip250mStimer;
// Alarm callback function.
alt_u32 lwipAlarmCallback(void* context)
lwipProcessTimerFlag = 1; // Set flag to process timers
return lwipTicksPer250mS;
// UDP callback function.
void UDP_Receive(void *arg, struct udp_pcb *upcb, struct pbuf *p,struct ip_addr *addr, u16_t port)
struct ip_addr dAddr = *addr;
if(p != NULL)
udp_sendto(upcb,p,&dAddr,port);
pbuf_free(p);
// Define netif for lwIP
struct netif alteraTseNetif;
struct udp_pcb *UdpPcbR;
int main()
char udpdata[] = "UDP has Initialed successfully, begin to transfer!\r\n";
static struct ip_addr ip_zero = { 0 };
struct pbuf *psend;
struct udp_pcb *UdpPcbS;
void httpd_init(void);
mSdelay(1000);
// test_jtag_uart();
printf("Running...\n");
lwip250mStimer = 0;
lwipProcessTimerFlag = 0;
lwipTicksPer250mS = alt_ticks_per_second() / 4;
if (alt_alarm_start (&lwipAlarm, lwipTicksPer250mS, lwipAlarmCallback, NULL) < 0)
printf ("System clock is required!\n");
for(;;
// Load platform specific MAC address into netif
alteraTseNetif.hwaddr[0] = 0x00;
alteraTseNetif.hwaddr[1] = 0x1C;
alteraTseNetif.hwaddr[2] = 0x23;
alteraTseNetif.hwaddr[3] = 0x17;
alteraTseNetif.hwaddr[4] = 0x4A;
alteraTseNetif.hwaddr[5] = 0xCB;
// Initialize lwIP, Altera TSE and the ethernetif
lwip_init();
if(netif_add(&alteraTseNetif, &ip_zero, &ip_zero, &ip_zero, alteraTseNetif.state, ethernetif_init, ethernet_input) == NULL)
printf( "Fatal error initializing...\n" );
goto fatal;
netif_set_default(&alteraTseNetif);
// Initialize Altera TSE in a loop if waiting for a link
printf("Waiting for link...");
while(((struct ethernetif *) alteraTseNetif.state)->link_alive!=1)
mSdelay(1000);
putchar('.');
tse_mac_init(0, alteraTseNetif.state);
printf("OK\n");
STATIC_IP;
STATIC_NM;
STATIC_GW;
netif_set_addr(&alteraTseNetif, &lwipStaticIp, &lwipnetmask, &lwipgw);
//netif_add(&alteraTseNetif, &lwipStaticIp, &lwipnetmask, &lwipgw, NULL, ethernetif_init, ethernet_input);
//netif_set_default(&alteraTseNetif);
netif_set_up(&alteraTseNetif);
printf("IP address: %s\n", ip_ntoa(&alteraTseNetif.ip_addr));
printf("IP netmask: %s\n", ip_ntoa(&alteraTseNetif.netmask));
printf("IP gateway: %s\n", ip_ntoa(&
alteraTseNetif.gw));
# if BUILD_HTTPD
httpd_init();
# endif
Init_UDP();
STATIC_DA;
printf("UDP Dest IP address: %s\n", ip_ntoa(&destAddr));
//psend = pbuf_alloc(PBUF_RAW, sizeof(udpdata), PBUF_POOL);
psend = pbuf_alloc(PBUF_RAW, sizeof(udpdata), PBUF_RAM);
psend->payload = (void *)udpdata;
if (!psend)
printf("Can't allocate buffer.\n");
goto fatal;
UdpPcbS = udp_new();
if (!UdpPcbS)
printf("udp_new() failed.\n");
goto fatal;
udp_bind(UdpPcbS, &lwipStaticIp, 67);
if (udp_bind(UdpPcbS, &lwipStaticIp, 67) != ERR_OK)
printf("udp_bind() failed.\n");
goto fatal;
udp_connect(UdpPcbS, &destAddr, 67);
if (udp_connect(UdpPcbS, &destAddr, 67) != ERR_OK)
printf("udp_connect() failed.\n");
goto fatal;
// This is the main loop for lwIP - other processing can be done by calling application functions.
printf("SUCCESS\n");
while(1)
udp_send(UdpPcbS,psend);
mSdelay(1000);
fatal:
for(;;
// Process lwIP timer dependent code
if(lwipProcessTimerFlag)
lwipProcessTimers();
// Poll lwIP for incoming packets.
ethernetif_input(&alteraTseNetif);
return 0; */
//UDP Init
void Init_UDP()
UdpPcbR = udp_new();
udp_bind(UdpPcbR, IP_ADDR_ANY, 67);
udp_recv(UdpPcbR,UDP_Receive,NULL);
// Run this every 250mS to update lwIP timers
lwip250mStimer += 250;
if( (lwip250mStimer % TCP_TMR_INTERVAL) == 0 ) { tcp_tmr(); }
if( (lwip250mStimer % ARP_TMR_INTERVAL) == 0 ) { etharp_tmr(); }
# if IP_REASSEMBLY
if( (lwip250mStimer % IP_TMR_INTERVAL) == 0 ) { ip_reass_tmr(); }
# endif
# if LWIP_AUTOIP
if( (lwip250mStimer % AUTOIP_TMR_INTERVAL ) == 0 ) { autoip_tmr(); }
# endif
# if LWIP_IGMP
if( (lwip250mStimer % IGMP_TMR_INTERVAL ) == 0 ) { igmp_tmr(); }
# endif
# if LWIP_DHCP
if( (lwip250mStimer % DHCP_FINE_TIMER_MSECS ) == 0 ) { dhcp_fine_tmr(); }
if( (lwip250mStimer % (DHCP_COARSE_TIMER_SECS*1000) ) == 0 ) { dhcp_coarse_tmr(); }
# endif
# if LWIP_DNS
if( (lwip250mStimer % DNS_TMR_INTERVAL) == 0 ) { dns_tmr(); }
# endif
