13 years ago2 read pulses after an IORD_16DIRECT
we are implementing the isp1763A on our custom board. when we do an IORD_16DIRECT at address 0x00 the system generate 2 Read pulses at address 0x00 and 0x02 ISP1763 is configured in SRAM 16bit ...
13 years agoYes, this is pretty normal.
If you search the forum you'd find other threads related to this issue. Avalon bus always performs a complete 32bit access, even if you limit the required data to 16 or 8 bit. Then, with a IORD_8DIRECT you'd get 4 read pulses. I had once a situation similar to yours where a fifo register was involved and the second read pulse was to be avoided. I solved it with the following trick: - extend the sram interface to 32bit, but connect only 16 lower bits - shift sram address lines in order to match 32bit addressing - IORD_32DIRECT and discard the upper 16bits A more clever solution would involve gating the read pulse according to address, I mean the rd pulse is passed to sram interface only if address is a multiple of 4; rd pulse instead is blocked if address=4*N+2
