10 years agoFFT Megacore sink_ready never goes to 1
Right now I am trying to read 16 bit values from memory and put the data into the FFT Megacore function I have in my design. The only problem is that in my Verilog project, the sink_ready value never...
8 years agoHi Behrazv,
Yes, this is important to issue an reset to the IP at the beginning of the simulation or when you power up the device. If the sink_ready signal becomes don't care (Stx) in simulation, it could be due to certain library files was missing. Assuming you are using Model-sim to run the simulation, you may refer to the simulation script "msim_setup.tcl" that generated by the IP for all of the necessary simulation files. Best Regards, Terence (This message was posted on behalf of Intel Corporation)
