10 years agoFFT Megacore sink_ready never goes to 1
Right now I am trying to read 16 bit values from memory and put the data into the FFT Megacore function I have in my design. The only problem is that in my Verilog project, the sink_ready value never...
10 years agoAlright I was able to dig a bit deeper into the forums and discovered that if you assert reset-n, then sink_ready generates a signal of '1' afterward. I was under the impression that reset-n was to be asserted only after the use and not prior. I'm still trying to figure out how to pass data into the FFT but seeing sink_ready finally go to 1 is a good first step and I hope someone experiencing the same issue can quickly read this instead of having to dig deep as I did.
