9 years agoCyclone V Hard memory controller rate
Hi, I am using Cyclone V which has 2 Hard memory controllers. When I tried to generate DDR3 memory controller with Uniphy I was not able to select Half or Quarter rate on Avalon-MM interface. Then I ...
9 years agoAs you pointed out above, the Cyclone V hard controller only supports a full-rate local interface. So the answer is no. And you can't go wider because the hard controller only supports up to 40 bits. Maybe jump to the Arria family?
