9 years agoCyclone V Hard memory controller rate
Hi, I am using Cyclone V which has 2 Hard memory controllers. When I tried to generate DDR3 memory controller with Uniphy I was not able to select Half or Quarter rate on Avalon-MM interface. Then I ...
9 years ago --- Quote Start --- What speed are you trying to run the external memory at and what data width? --- Quote End --- I want to run external memory at 400Mhz or 500Mhz and its a 32 bit memory.
