8 years agoButterworth Low Pass filter Implementation
Hi, In my application I need to implement high order Butterworth Low Pass filter to ~1Hz from 32bits, ~50ksps input signal. How can I evaluate the filter performance and estimate the resources...
8 years agoI believe we put you on the hard bumpy track
Anand's response on behalf of Intel is too empty for such responsibility but thanks anyway for contributing FvM has shrouded it with too much complexity. After all multi rate approach will require its own filter or chain of filters. Away from butterworth or no butterworth you better define your filtering requirement in terms of cutoff frequency, attenuation in dB ...etc. You want a proper filter rather specifically butterworth type.
