8 years agoButterworth Low Pass filter Implementation
Hi, In my application I need to implement high order Butterworth Low Pass filter to ~1Hz from 32bits, ~50ksps input signal. How can I evaluate the filter performance and estimate the resources...
8 years ago --- Quote Start --- Hi, Yes can use cyclone V device family. For Knowing the resources you can design a project which is easier way to find resources required. Or Use FIR II IP Core Performance and Resource Utilization page 9. and find out resources required. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_fir_compiler_ii.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Hi, Thank you for your quick response! According to the FIR II IP I can't implement Butterworth Low Pass filter- only Decimation (and Interpolation and Decimation half-band…not Butterworth). Am I right?
