agula
6 years agoAria 10 PCIe Avalon Stream SR-IOV Example Simulation
I am unable to get the example design up and running with the Aria 10 PCIe express example design with SR-IOV. This is covered in Section 2 of the following documentation:
https://www.intel.c...
mark_lee
5 years agohi agula
where can i downloal the SR-IOV example for ariia10 device?
thanks!
agula
5 years agoHi,
Should be in the IP folder of your Quartus download. The examples should be marked SRIOV. I used the 2 PF and 4VF example design. If you load the .qsys file into platform designer you should be able to generate a test bench for the system.
