8 years agoAdd Block-CRC verification acceleration support ????
Hallo In the PFL IP core settings there is this option to to turn or Add Block-CRC verification acceleration support. The description says ''adds a block to accelerate verification (only availa...
8 years agoHallo
Thanks a lot for your reply. I was just concerned because turning on/off the block makes a change in the number of L,E used. And when i turn off this option i just found out that i could use a smaller MAX device with lower L.E count just to reduce the cost, but after your reply it looks like, to keep the block turned on and use a bigger MAX device is a better idea. Sorry for the late reply, for some reason, i didn't get a e-mail notification of your answer.
