15 years agoWriting EPCS64 Device For Remote Update
Hi, I would like to use the Remote Update mode of Cyclone III device. I have achieved lots of things but I could not accomplish writing EPCS64. I want to write my factory image hw1+sw1 at base...
15 years ago --- Quote Start --- You'd also have to modify the bootloader for the second pair or, like I've done in the past, just use a separate onchip memory for this bootloader. I can describe an approach for doing this, if you like, but I'd recommend reading the following AN (and, perhaps, playing with the source code) before that: http://www.altera.com/literature/an/an458.pdf --- Quote End --- Hi slacker, I have read the AN458 document however I could not do examples because I use Qautus 8.1 and Nios 8.1. How did you achieve remote update by using a seperate on-chip memory? best regards, thanks
