15 years agoWriting EPCS64 Device For Remote Update
Hi, I would like to use the Remote Update mode of Cyclone III device. I have achieved lots of things but I could not accomplish writing EPCS64. I want to write my factory image hw1+sw1 at base...
15 years ago --- Quote Start --- I run the srec_cat.exe then in the opened window I executed... --- Quote End --- You need to run srec_cat from a command line instead of running it from the Windows GUI. You can use either the Windows "Command Prompt" or the "Nios II Command Shell". I would recommend using the Nios II Command Shell as it is easier to use the other Nios command line tools this way. On my system I have also added the location of srec_cat.exe to the system path so that it can be more conveniently executed from any location.
