15 years agoWriting EPCS64 Device For Remote Update
Hi, I would like to use the Remote Update mode of Cyclone III device. I have achieved lots of things but I could not accomplish writing EPCS64. I want to write my factory image hw1+sw1 at base...
15 years ago --- Quote Start --- No, the GUI isn't capable of doing what you're asking of it. You'll have to use (and understand) the command line tools (sof2flash, elf2flash, and nios2-flash-programmer) in order to do what you'd like. You'd only have to modify the bootloader for the second pair of images. The first pair of images can use the stock bootloader. Alternately, you can use the methodology presented in AN-458. Also, before you go through any of this sort of exercise, you'd better make sure you actually have enough space in the EPCS device to do what you'd like to do. Regards, slacker --- Quote End --- slacker thanks very much, I have tried the sof2flash and elf2flash commands before I asked the forum. The problem was that when I have tried to give an offset to sof2flash command for example --offset=0x00200000, the created flash beginning address was still 0x00000000. Then when I looked at the datasheet of EPCS devices, I saw that the offset command is valid only for CFI Flashes. What can I do so as to give an offset? thanks again.
