15 years agowrite to segment (multiple locations) of memory
Please see post# 6 for a better formulation of the problem. ------ Hi! I have a question about the memory blocks that are available on the Altera FPGA chips. Is it possible to wr...
15 years agoits not as simple as what you want. What you want to do is not possible. The max D word width for M9K is 36 bit iirc, and 72 or 144bit for M144k.
You could try muxing your words eg. have a 32 bit dword, with the least sig. bits of the adderss as byte select, and then you can write 4x8bit words at once.
