KLohr
7 years agoWorking on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that ...
KLohr
7 years agoI was able to finally configure and program the device encrypted by moving my initialized UFM from 0x000 to 0x1000. Apparently I was overwriting the key and ICB stored at 0x000. My concern now is , our customer wants to program the CFM with the encrypted FPGA program during mfg, then calibrate the device and program the UFM at a later time (without changing the encrypted CFM).
Before encryption, we have been doing this by converting the intel hex file and then programming the UFM only with the programmer. I can't seem to do this without affecting the stored key and ICB at 0x000 to 0x7FF?
If you have any insight into this, I would appreciate some feedback.
