KLohr
7 years agoWorking on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that ...
KLohr
7 years agoAre you sure about this licensing issue max 10 devices? From the an556 it doesn't mention max10 devices. I never got any warnings from the quartus software. I wonder if my issue is that I was trying to use the UFM at 0x000 to 0x403 and it sounds like that is used by the ICB.
