KLohr
7 years agoWorking on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that ...
KLohr
7 years agoSorry, just noticed the addresses in the map file are byte addresses.
