KLohr
7 years agoWorking on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that ...
KLohr
7 years agoWe also have a standard and pro license, but our customer does not. I noticed from the configuration guide it said "the key is part of the ICB settings stored in the internal flash" I am using the UFM. How much memory do the ICB settings take in the UFM? I noticed from the .map file it said "ICB 0x00000000 0x000007FF" Does it use that entire area? Is that byte addresses or 32bit addresses?
