KLohr
7 years agoWorking on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that ...
KLohr
7 years agoaiu_fpga_encrypted.map :
BLOCK START ADDRESS END ADDRESS
ICB 0x00000000 0x000007FF
UFM 0x00000800 0x0001CFFF
CFM0 0x0001D000 0x0004E7FF (0x000462A0)
Max 10 Setting:
EPOF: ON
Verify protect: ON
Watchdog value: Not activated
POR: Instant ON
IO Pullup: OFF
SPI IO Pullup: OFF
Notes:
- Data checksum for this conversion is 0x035D1876
- All the addresses in this file are byte addresses
