14 years agowill add a module or IP change the performance? (combining SDI and SGDMA)
Hi all I'm wondering whether adding a module or an IP to an FPGA design can change the performance. From what I know, I guess the performance would be changed because different place and rout...
13 years agoHello, YUFU0511!
Do You mean, that You did not use any custom HDL blocks to connect CVI and SGDMA and You had no problems ? What SGDMA did You use - QSys component SGDMA or Wiki Modular SGDMA?
