14 years agowill add a module or IP change the performance? (combining SDI and SGDMA)
Hi all I'm wondering whether adding a module or an IP to an FPGA design can change the performance. From what I know, I guess the performance would be changed because different place and rout...
14 years agoNo, base address has nothing to do with the memory offset. The base address is required for Nios to access module registers. Check frame buffer documentation.
