14 years agowill add a module or IP change the performance? (combining SDI and SGDMA)
Hi all I'm wondering whether adding a module or an IP to an FPGA design can change the performance. From what I know, I guess the performance would be changed because different place and rout...
14 years agoHi Socrates
I just found two unassigned IO pins which should be connected to SDI cable driver IC. After I assign correct IO pins, the combined project works stable. So I move on to write the C program running on NIOS II CPU to control the SGDMA. A new problem occurs which makes SDI receiver reset. If I declare the video frame buffer in "stack" of DDR3, the downloading process of elf file is slow. (about 5 second...)
alt_u8 video_buf __attribute__((section(".ddr3")));
I guess this slow process somehow makes SDI receiver reset. (rx_status[1] is 1'b1) So I allocate video frame buffer in "heap" of DDR3 to solve the slow downloading problem and it works. (rx_status[4] which indicates frame locked is 1'b1) Thank you for your help.:)
