14 years agowill add a module or IP change the performance? (combining SDI and SGDMA)
Hi all I'm wondering whether adding a module or an IP to an FPGA design can change the performance. From what I know, I guess the performance would be changed because different place and rout...
14 years agoThe problem is that SDI is a continuous stream and SGDMA use bursts for DDR3. Check Altera frame buffer IP core, but think of a mechanism how to make SDI stream to do bursts in packets.
