Why would these two clear on reads behave differently?
- 6 years ago
Well, that looks basically ok.
I would have to assume that input CS is only valid for a single clock cycle. Correct?
Or if CS is valid for more than one clock cycle then SPI_RD is only valid for one clock cycle.
Otherwise if CS and/or SPI_RD is present for two (or more cycles) the register will be read once, then cleared, then read again with the value zero.
So it looks like SPI_RD was high for too many cycles, and the data were being read, then cleared, then read again like you described.
We added logic to only clear status_reg after the register had been read by the SPI.
To do this, we separated the two operations into two SPI commands.
Since status_reg is continuously updated, we added status_temp to preserve any new statuses that come in during the time after we read the status_reg but before we clear it.
//during read
begin data_out <= status_reg[15:0]; status_temp[15:0] <= status_reg[15:0]; end
//after read
status_reg <= (status_reg[15:0] ^ status_temp[15:0])|(status_reg[15:0] & 16'b1110000000110001);
Thanks for your help!
