BQi
6 years agowhy we can not generate pcie ep ipcore example design?
we use below ip config, but we can not generate pcie ep ipcore example design, pls help
BoonT_Intel
6 years agoHi Sir,
What is the IP that you using and what FPGA device?
Based on the IP file that you attached in this thread early. I am open it with Quartus 19.4 and it give me Avalon-MM Intel S10 Hard IP for PCIe.
And based on this IP, the Avalon-MM setting tab is looks like this screenshot.
It is different from your screenshot. And the parameter that I mentioned is the “Address width of accessible PCIe memory space” as highlight in yellow. You should set it to 62 or below.
