BQi
6 years agowhy we can not generate pcie ep ipcore example design?
we use below ip config, but we can not generate pcie ep ipcore example design, pls help
BoonT_Intel
6 years agoHi Sir,
I tried to generate using your IP file and also get the error during generation. Can you list out which setting that you wish to generate? I think maybe we need turn on one by one and determine which setting cause the error. By the way, do you try other pro version?
- BQi6 years ago
The all parameter is in *.ip One lane PCIe EP instant We only have QII 19.4
