18 years agowhy the module is synthesized away?
hello, i got a problem, here is the my code : attachment 1 and part of the top module is below: attachment 2
18 years ago --- Quote Start --- thank you, i think its the point, according to you suggestion, i will check my design and make sure if this is the point of the problem.thanks again. --- Quote End --- Hi, maybe I'm wrong, but I think your clkcnt is the problem: //clkcnt always@(negedge CLOCK or negedge RESET_X) begin if(!RESET_X) begin clkcnt <=# P_DLY 6'd0; end else if(READ_RAM_ENABLE == 1'b1) begin if(clkcnt == 6'd40) clkcnt <=# P_DLY clkcnt + 6'd1; else clkcnt <=# P_DLY clkcnt; end else clkcnt <=# P_DLY 1'b0; end The counter will never count, because after reset the clkcnt is set to "0". Your counter can only count at clkcnt = 40, but you will never reach this value.
