18 years agoWhy the gxb tx_pll loses lock --Stratix IIGX
:confused:
Hey all: I 'm using the Stratix IIGX(EP2s30) to realize the high speed serial communication,I met a problem that the GXB tx pll loses lock when simulating with vwf file。The output of epll is fed to the GXB tx pll_inclk, and the tx_pll_cascade is on. I try to use the refclk pin to fed the pll_inclk, but the tx pll doesn't work due to the noise(Peak to peak 400mv).No RepliesBe the first to reply
