15 years agoWhy MAXII CPLD only output 1.6v when high (3.3V LVTTL)
VCCIO and VCCINT are both 3.3v, and the pins are set to 3.3v LVTTL in quartusII, but the output is only 1.6v when high after I downloaded my program into the device(epm240t100c5) Could any bod...
15 years agoNothing, No load connected.
I use VOM(Volt-Ohm-Milliammeter)to the measue the Voltage. And the output with pulse, I suspect the pulse cause the VOM(Volt-Ohm-Milliammeter)measurement not accurate. How do you think?
