13 years agoWhy it wants mofr M9K blocks
Cyclone 3 - device has 66 M9K blocks. I set up 16384x36 memory chunk. It is 589824 bits, with device having 608256 bits. However quartus says it is too much, and says device needs to have 72 blo...
13 years ago --- Quote Start --- and the explanation (as far as I know) is that the parity bit is available across 1024 locations (or spread across as 2*512,4*256). any depth > 1024 loses it. This parity bit itself is not used as parity in the first place! as far as I know. --- Quote End --- Oh thank you so much - it worked!
