13 years agoWhy it wants mofr M9K blocks
Cyclone 3 - device has 66 M9K blocks. I set up 16384x36 memory chunk. It is 589824 bits, with device having 608256 bits. However quartus says it is too much, and says device needs to have 72 blo...
13 years ago --- Quote Start --- Do you have option of maximum block depth. setting this option can change the memory requirements. Try it in megawizard and read the resource in M9k directly on the wizard. --- Quote End --- Wizard says block type "auto" and max block depth "auto". Resource really says 72 M9K. I have played with number of words. Choosing 1024 gives 4 M9Ks, but choosing 2048 (twice more) gives 9 (nine!) M9Ks! I also played with bus width and it seems to me that 9th bit of the M9Ks is being lost in my setup. When I set bus width to 32 bits, it properly displays 64 M9Ks.
