13 years agoWhy it wants mofr M9K blocks
Cyclone 3 - device has 66 M9K blocks. I set up 16384x36 memory chunk. It is 589824 bits, with device having 608256 bits. However quartus says it is too much, and says device needs to have 72 blo...
13 years ago --- Quote Start --- Okay guys, I created new RAM instance, 1-port, and it still says I can not fit 16384x36 memory into the cyclone 3 chip (Q240), and it needs 72 M9K blocks instead of expected 64. There should be something wrong. --- Quote End --- Do you have option of maximum block depth. setting this option can change the memory requirements. Try it in megawizard and read the resource in M9k directly on the wizard.
