13 years agoWhy it wants mofr M9K blocks
Cyclone 3 - device has 66 M9K blocks. I set up 16384x36 memory chunk. It is 589824 bits, with device having 608256 bits. However quartus says it is too much, and says device needs to have 72 blo...
13 years ago --- Quote Start --- It depends on the dual-port mode you are using - see pages 43-46. http://www.altera.com/literature/hb/cyc3/cyclone3_handbook.pdf Based on the error message, I'd guess you were trying to use true dual-port mode. Cheers, Dave --- Quote End --- Not sure... Seems to be simple mode. BB file shows module scope_mem ( clock, data, rdaddress, wraddress, wren, q);
