10 years agoWhy is the use of different PLL feedback modes in Altera devices?
The documentation states that the Altera PLLs have 6 different clock feedback modes. These are: 1. Direct mode 2. Normal mode 3. Source-Synchronous mode 4. External Feedback mode 5. Ze...
10 years ago --- Quote Start --- The documentation states that the Altera PLLs have 6 different clock feedback modes. These are: 1. Direct mode 2. Normal mode 3. Source-Synchronous mode 4. External Feedback mode 5. Zero-Delay Buffer mode 6. LVDS mode Why are there so many clock feedback modes and how do I know which one I need? --- Quote End --- They are offered to tackle timing problems in case you have io violations. Direct : only de-jitters clock, does not compensate for delay. normal, de-jitters and reduces clock delay from pin to register and compensates for clock delay from pin source synchronous, keeps data/clk phase same between pins and registers external: relevant if so zero delay: relevant to an output clock from pll, maintains same phase of output clock as that of input clock. lvds: relevant to serdes.
