15 years ago
Why filter output is like this ?
Hi . Details of FIR filter
FIR rectangular Window
BPF
Order 3
No. of coefficients = 4
Fc1 = 1 Hz
Fc2 = 24 Hz
Fs = 100 Hz
figure 1 (https://picasaweb.google.com/lh/photo/twkb1ndv70nlf_yyldlubw?feat=directlink) shows the Simulink model of symmetric FIR realization.
figure 2 (https://picasaweb.google.com/lh/photo/iy3punhc3homoffa0gfrfa?feat=directlink) shows the comparison of ( top to down ) input, Simulink model o/p, o/p using HDLimport after generating HDL code from the model for the filter subsystem.
figure 3 (https://picasaweb.google.com/lh/photo/xpenvlyowzlwfpm2scsxrg?feat=directlink) represents complete model.
My doubt is why there is a difference in the o/p values in both cases ie, normal subsystem using simulink blocks and subsystem using HDLimport.
Filter coefficients were obtained using FDAtool which are
[0.143537584073133
0.415799512456997
0.415799512456997
0.143537584073133]
I tried with higher filter order ( 12, 16, 32 ) , but results were very poor.( some sort of square pulses at irregular intervals).
i used fixed point rep. as follows
for i/p = 16(10+6)
for coeff. = 16(10+6)
Thank you.
