13 years agoWhy Clk Oscillator waveform is not square in the oscilloscope?
If some body knows please help me regarding these two below questions. 1- Why board's Clock waveform is not square in the oscilloscope? As I am new I use this simple code: architecture beha...
13 years agoThank you for information. My FPGA board is Cyclone II and it has three clock 50 Mhz, 27 Mhz and 24 Mhz. I am using the 50 Mhz clock now and I want to see the clock signal (normally it should be as a square waveform) but it is not square. Also as you said I am going to check the scope and probes.
According to the delay could you please be more specific and if there is any examples guide me. Please introduce me links, references or extra information. Thank you so much.
