13 years agowhich message is sent from DE115 in wireshart capture file
https://skydrive.live.com/redir?resid=e0ed7271c68be47c!302 can i send data through ethernet like this and captured by wireshark? or i need to send a real ethernet frame? LIBRARY ieee;...
13 years agoNo it's two nibbles in one clock cycle. You can use the Altera DDR I/O primitive to do this: http://www.altera.com/literature/ug/ug_altddio.pdf
Is there any reason why you aren't using a MAC such as the Altera TSE? It would make your life a lot easier.
