18 years agoWhere can I find clock mux?
Hi, everyone. In my project, 2M,4M,8M and 16M bitstreams will be transived to the reciver. For the reciver, it must know the clock which the bitstream contains. The cyclones have no DPA or CDR, so...
18 years agoThank you very much,Rysc.
Compared to the first way you stated, I think the other one may run at higher speed. Use pll to create all the frequencies i need, but the pll only can create 3 frequencies sometimes only two different frequencies . I need four different frequencies used as clock, can I use more than one Pll to create the clock i need ? (Of course the input clock is the same one) In my opinion (if i understand you correctly)what your suggestion is to avoid the design fabric as i described in my post, is it? In order to get a higher speed such as more than 400M , I can't find a better way to deal with the problerm i mentioned on my post with the cyclone series.
