13 years agowhen use JTAG mode and switch to Run/Prog and programmer to start, no response
1. i am doing Lab1 of DE115 when use JTAG mode and switch to Run/Prog and programmer to start, no response when i on or off switch, it is still the original situation which blinking and co...
13 years ago --- Quote Start --- JTAG only programs the FPGA. When power is removed and reapplied it will load the program that is in the configuration device. You need Active Serial to program the configuration device. --- Quote End --- a. I success program to it, i would like to see whether the boards work as normal every time i switch on it why need Active Serial to program, why not JTAG ? b. after Active serial program Lab1 into it, i toggle the switch, it do not switch off, where is wrong?
