13 years agowhat's non-inverted input pin ?
Hello, During complete my project, I stuck at a problem with pll. I use kit Cyclone III devlopment kit I try to use clock 50MHz to feed pll1 by pin AH15. During synthesing and analyzing it re...
13 years ago --- Quote Start --- I cannot tell you without knowing the exact part number of the FPGA. Post a link to the "Cyclone III development kit" you are using and I'll look. I'm not sure what you are asking here. If the signal is defined as differential, then the FPGA will use a differential receiver to receive the clock. If however the clock is defined as single-ended, then the FPGA will use a single-ended buffer. In that case, the single-ended signal may be restricted to enter the device on the DIFFCLKIN_P pin. I don't recall whether this is always the case. Typically I synthesize a design using Quartus to confirm clock assignments. The details on which clock pins route to what PLLs can also be found in the handbook for the device you are using. Start by posting a link to the kit, and I'll point you to the appropriate place in the Cyclone III handbook where it provides the information. Cheers, Dave --- Quote End --- My kit is "cyclone III 3c120 dev" Here is its link: http://www.altera.com/products/devkits/altera/kit-emb-dev-cyc3.html
