RShal4's avatar
RShal4
7 years ago
What's "new design non-NIOS II" ?
In peripheral embedded ip user guide, there are several IP , in which it is said:
"For your new (non Nios II) designs, Intel recommends you to..."
What is non Nios II ? Isn't NIOS II the latest ?
  • If you do use Nios, use the IP in the embedded IP user guide. If you do not use Nios, use the IP linked to in the note for that IP.
    #iwork4intel
  • sstrell's avatar
    sstrell
    #iwork4intel
    • RShal4's avatar
      RShal4
      thank you very much
  • sstrell's avatar
    sstrell
    The document is saying that if you are creating a design that does not use a Nios processor for control, you should use the different IP referenced.
    #iwork4intel
    • RShal4's avatar
      RShal4
      Thanks, I am not sure I understand yet.
      If I do use NIOS II processor, than the recommendation is not relevant ?
      for example Intrel recomments the generic flash instead of generic quad , Is this recommendation not relevant for NIOS II ?
