13 years agoWhat kind of JTAG this board is using?
Hello, I'm following a tutorial PCB board for Cyclone 4. I'm using the design found here provided by one man has done it before: https://bitbucket.org/avakar/omicron_analyzer/src/00e2960f9...
13 years ago --- Quote Start --- Yes. You should find the pinout of the USB blaster 10-pin connector in the USB blaster user manual. --- Quote End --- Thanks Daixiwen. Only one more doubt. It's good that he connected the pins to 2.5V instead of 3.3V , but he didnt connect them to any pull up or pull down resistors. Is that safe to do so?
