13 years agoWhat kind of JTAG this board is using?
Hello, I'm following a tutorial PCB board for Cyclone 4. I'm using the design found here provided by one man has done it before: https://bitbucket.org/avakar/omicron_analyzer/src/00e2960f9...
13 years ago --- Quote Start --- AFAIK there isn't a JTAG connector pin-out standard. Although the 10-pin configuration used by Altera on the USB Blaster is quite common among different manufacturers, I've also seen some 6 pin variations. You should be able to use it with a USB blaster but you will need to make an adapter cable to connect the different signals to the correct pins. --- Quote End --- Dear Daixiwen, by conencting "the different signals to the correct pins", you mean I just connect the pin from his JTAG port to the correct pin of the USB blaster, right?
