15 years agoWhat is the processing speed limitation of Cyclone IV E with speed grade C7?
Hi everyone, Does anyone know, what is the maximum processing speed of Cyclone IV E (with speed grade of C7) within the FPGA fabric? Knowing that PLL on Cyclone IV E can generate up to 1....
15 years ago --- Quote Start --- Wow.... that CARMA board is really impressive.. --- Quote End --- Thanks :) --- Quote Start --- I will try to read your material as my main reading material for the rest of my summer holiday, and hope to understand maybe 20-40 % of it. --- Quote End --- Make sure to both read and write some code. If you can understand how to create a simulation that generates and captures your serial data, you will have a good chance of getting it working in hardware. Don't forget that with a loopback from TX-to-RX your 'simulation' can also be tested in hardware. --- Quote Start --- Thanks for your help, i really appreciate it.:-P --- Quote End --- No problem! Keep asking questions. Welcome to engineering, its a lot of fun! Cheers, Dave
