18 years agoWhat is the meaning of Small C library
Hi, In system library properties there is option called small C library, enabling and disabling this option means what?. and also what is clean exit, what does this do?. thanks, Ana...
18 years agoHi,
I tried all sorts things like; increasing on chip memory to 50KB , all works fine only when I enable small C library. But If I enable small C library along with perfomance counter, I c that perfomance counter stays in reset state itself. can u think of anything else where I can rid of this small C library, I included SDRAM controller, build is fine.. but I am not able to downlaod it to fpga it says "no Nios II core found leaving target processor" why is this because of?. I just added a SDRAM controller of width 16 bits and On chip ram of 50KB and gave CPU with SDRAM as reset vector and exception vector. Is there anything which I left out and anything istake I have done?. Thanks, Anand
