18 years agoWhat is the meaning of Small C library
Hi, In system library properties there is option called small C library, enabling and disabling this option means what?. and also what is clean exit, what does this do?. thanks, Ana...
18 years ago --- Quote Start --- hi, ... error saying that " region needs to be larger 7000 bytes etc...". --- Quote End --- This is what I mean "whenever you need a smaller footprint" --> You don't have enough RAM to fit in your program, your program is too big either because it is really big or you code is not effective So --> Increase the memory size if you are using onchip memory else try to remove unnecessary code if you can't change the external memory
