sandar1
4 years agoWhat is the difference between EN6360QI and EN6360QA?
I compared both data sheets of EN6360QI and EN6360QA but i didn't find any differences between them.
Can you advise if there is any difference between those parts?
Can i use EN6360QA as an altern...
YuanLi_S_Intel
4 years agoThere is no direct replacement for the part. However, if the pin placement is compatible and also the data specification is meeting your board requirement. It is fine. Meanwhile the the resistor requirement, it is mandatory as per the datasheet.
