sandar1
4 years agoWhat is the difference between EN6360QI and EN6360QA?
I compared both data sheets of EN6360QI and EN6360QA but i didn't find any differences between them.
Can you advise if there is any difference between those parts?
Can i use EN6360QA as an altern...
YuanLi_S_Intel
4 years agoThe differences is just the feature and some electrical characteristic. You can check from the datasheet. Yes, you can as long as it meets your design specification.
- sandar14 years ago
For EN6337QA (Automotive version), we have a concern about Pin number 22. The datasheet says that the part must connect a 560 ohm resistor from PVIN to PG. This resistor doesn't exist on our board and specifically noted to not be there for the non-automotive part.
Can you answer the following question for me?
Is it ok to use EN6337QA as an alternate of EN6337QI without having a 560 Ohm resistor at pin 22 (From PVIN to PG)?
Please advise. Thank you!
