MTuck8
7 years agoWhat files to version control of PLL IP entity?
I need to add a PLL entity to my otherwise very portable & clean VHDL code. When using the Quartus IP library wizard to create a PLL I end up with about 10-20 files in my projects some of which loo...
MTuck8
7 years agoThat does not sound like a good solution for an active open source project (you want all files to be in source form / plain text).
Is there no pure HDL solution for instantiating a PLL? For instance, block RAM and DSP functions (multiplication) can be infered from regular HDL constructs. An Intel library of common IP (e.g. a PLL) would be very useful.
kadon
7 years agoperhaps creatr one set of IP files for every version of Quartus, and add them all to the Git repository?
https://redtube.onl/ https://beeg.onl/ https://spanktube.vip/spankbang/
