15 years ago
What does this "pu1" of the clk means in the modelsim-altera ?
What does this pu1 of the clk means in the modelsim-altera ?
The verilog codes of the cam in the cookbook (http://www.altera.com/literature/manual/stx_cookbook.pdf). There's 5 files:
ram_block.v
ram_based_cam_tb.v
ram_based_cam.v
cam_ram_block_tb.v
cam_ram_block.
All the files are compiled in the Quartus 11 successfully.The 2 testbench files (ram_based_cam_tb.v & cam_ram_block_tb.v) are also successful,but in the Modelsim 6.6 ,the waves are wrong, the "clk" is "pu1", what does this means? How to correct it ?
    clk is pu1 ...
    I know the license of the Altera-modelsim is error, but in modelsim
    ,It is successsful that running these codes by importing the megafunctions of altera Manually ! There is no clk pu1
    "pu1" means pull up high. It's a state to model outputs with pull up resistors.
    Are you simulating the correct file? You should be simulating one of the test benches (_tb).
